janda240sx »
https://forums.nicoclub.com/janda240sx-u77387.html
Wed Jul 23, 2008 11:10 am
O.K. first off, He didn't say anything about the clutch engaging and disengaging the compressor. He just said it was cutting in and out. which means that, like you said, its low of refrigerant or the pressure is to high.
Maaayybe........ The pressure is reaching to high of a level and causing the compressor to shutdown. Now, what is the cause of high pressure? HEAT!!!! This means that the AC fan may not be working and is allowing the refrigerant to get to hot. However, this will not happen immediatly. The AC will have to be on for a while with no airflow for it to get this hot. But it is a possibilty.Educate yourself before you tell someone they are wrong. Oh and btw, I am a professional. If you still think i am wrong go ask another prof. and see for yourself.
