A/C Drier Compatibility to German 200SX
redline_ger
Car: Motorbike
Hello from germany.I have a 200SX, 1.8L Turbo , S13 chassis , frog eyesnon facelift from 1990.
I need help from someone which has a 240SX manualand the Nissan Part Numbers nearby.
I got a complete used A/C system which worked fine.I need a receiver/drier but Nissan germany wants 180$for it. I found some USA web sides where i canget a drier, R12 oil and also a complete set of O-ringswhich i need for this swap for 70$ + shipping.
The problem is that i can' t compare the part numbers.My research came to the result that it hasto be a 240SX from 1989 or 1990. The newer 240sx ones have a bigger compressor.
Your 89/90 version has also the same compressor listed as i have. It's an Atsugi Nihon NVR 140S.My Part Number would be 92131-40F01 (1990 - R12)
Can someone please compare this with a crossreferencelist or the 240SX service manual.It would be very nice if i could be shure .....
best regardsRainer
