stickface wrote:Every time I turn on the climate control, the A/C always comes on, even if it was in the off state when I turned it off. Even with the temp up around 76 degrees.
When the A/C light is on, it means that the air conditioning is eligible to come on, if conditions so dictate. This is essentially what 302@12psi told you.
When you say "Every time I turn on the climate control" do you mean every time you engage Auto mode from manual mode? If so, it's behaving normally. When you transition to Auto mode, the vehicle assumes you want it to "automatically" keep to the selected temperature and so, it enables the A/C.
If you want the system to do its best to maintain the temperature setpoint without using A/C, you can push the A/C button to turn it off. This setting will be preserved even if you turn the car off and back on again, as long as you keep it in Auto mode.
HTH,David
