ImStricken06 »
https://forums.nicoclub.com/imstricken06-u194849.html
Sat Jul 07, 2012 8:19 am
nope, its programmed to do, what it does.
folks gotta understand you bought a 4cyl engine. so expect smaller(weaker) a/c pumps, smaller(weaker) alternators, a little more engine shake/rattle, small vibrations upon power dips at stops, etc.
my suggestion is if you feel there is a problem, use your warranty. go to the dealer have them check the r134a levels, and or things like expansion valves, etc. sometimes a fresh recharge or a slight increase in freon will solve small issues. or sometimes sticky valves, air bubbles, moisture, can impede optimal performance.
trust me, i went from a 4-cylinder 1999 altima to a 6-cylinder 2002 nissan maxima. i got used to, the amazing a/c, miniscule power dips, almost no vibrations, on the maxima's six cylinders - and only to be culture shocked BACK again into the four cylinder engine by the Rogue lol
