NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Sun Jun 20, 2004 12:30 pm
Hey Everyone,
I just recently heard of a neighbour that had good results from puttin in Redtek R134a cans into his retro-fitted Oldsmobile. My '91 has been retrofitted but lost its charge during the last year. So, I decided to try what he did by 'topping up' with these pressurized cans. I put in a 'Stop Leak' product first and then straight R134a refill. I emptied both and then at the very end with the bottle still attached to the low pressure side, the A/C started cycling on and off.
My questions are:
Have I put in too much?
How cold is your A/C? I measure mine and it only reads about 12 deg. celcius or about 55 fahrenheit on setting '2' on the fan with A/C on.
Can I purge some pressure out of the low pressure side if there's too much, causing the dual pressure switch to come on?
I just don't understand why that would happen after draining all the fluid for about a minute it ran nice and then started cycling, leading me to believe that it may be just barely over the max pressure limit of the sensor. Can I just run it for a while and will it fall back into 'acceptable limits' within the sensor?
Thanks for your help!!
