Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Mon Sep 01, 2008 3:28 pm
Purely a guess, but I'm assuming that there is an A/C relay somewhere, probably under the hood. If this relay is flaky, it may be the culprit.Having said that, most A/C systems have a pressure valve/sensor, that senses when the system pressure is either too high or too low. If it's too high, then the compressor will cycle down. If it's too low, then the system will shut down completely. If the coolant level is borderline, then the system can cut in and out, just like you describe. Happened to me with my old Chrysler minivan.I'd have your system pressure tested, for starters.Good luck.
