A/C Controls GONE after radio replacement.
mhultman
Car: 1997 Q45
Hi everyone,
I just replaced my defunct radio in my '97 Q45 with one that matches the same year. Got the removal instructions from carstereoremoval.com which were great. They gave appropriate warning to not exchange the lighter plug with the dimmer switch plug and I heeded it accordingly. Unplugged everything, replaced the radio, plugged everything back in and the radio works perfectly. Now I have no indication or control of the Air Conditioning system!!!! All I did was unplug and then plug it back in. Is there some kind of reset I have to do? Anyone have this kind of experience before?
Any help would be appreciated!!! Thanks!
Medford Hultman
I fixed the problem. Apparently when you take the plug off you're in danger of blowing the AC fuse when you plug it back in. That was it. A freaking fuse!
Modified by mhultman at 2:51 PM 3/29/2008
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Count your blessings you got off with only a fuse.
