slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Mon Mar 14, 2005 8:17 pm
The S13 AC controls are mechanical buttons, so if they are not staying engaged, it's most likely a coicidence that wiggling the harness helps. Unless you like messing with this sort of thing, I'd replace the front panel. Think of the old-style tape decks with the mechanical buttons. If you ever took one apart, you'd know that they are a pain to get working properly again. Doesn't sound like an electrical problem: you're likely just stressing the front panel enough to catch a slider/pin/some sort of engagement mechanism.
