1991q45 wrote:well i'm happy to report there's no leaks...which was my main worry.so it turned out the adaptor was the problem with the leak.
and the a/c starts out ICE cold then gets hot.you can see the refrigerant and what looks to be bubbles...
Glad you had the non leak issue settled. Why do you think there are bubbles?
1991q45 wrote:okay the condenser itself was leaking.
now the air still gets cold then it gets room temp.the condenser fan is smaller than the oem could that be the reason why??
How can that be?
Did you read the FSM?
Take it to an exclusively automotive AC specialist. He can find the leak. Get a dryer and what ever other parts you need from Joe. Be sure to have the information form the manual for the amount of R12 and the correct lubrication the AC technician needs to replace after a complete (at least 1 hr.) evacuation of the system.
