A/C condenser causing overheating?
95nismoSX
Car: 89 coupe silvia front
I have a 1989 coupe with silvia front end and a sr20det swap, the condenser sits between intercooler and radiator, is there any relocation kits or was to move it, or a way to keep it there and fix the problem. its hot here in GA. and the car starts to run really hot when i run the ac if im not on the highway and even then its still too hot for comfort.(me and the car running temp) lol. there seems just to be to much heat bundled in one area.
2fizzleforshizzle
Car: 89 240SX 90 240SX
Do you run a low temp thermostat or upgrade radiator? That might be a good idea.
95nismoSX
no, all stock, would running a aux fan on a switch help also? and if i were to replace rediator, which companies or ones are affordable and not junk thats gonna leak in a year.
Q45tech
Due to oxidation radiators lose efficiency as they age. Any 10 year old rad can be improved upon with just a new oem unit. Carefil about aftermarlets which may weigh less and habe fewer thinner fins per inch.
Running wetter water and 30% AF ratio + 70% distilled water may help a few degrees.
The volume of coolant needs to be increased with an inlike aux tank to add 2,3,4 quarts.
95nismoSX
I have that mix of water and AF and an overflow tank.
95nismoSX
anyone know or have any idea how to do a condenser relocation or have tried with bad resualts.
