Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Aug 18, 2003 6:07 am
When I replaced the evaporator in my truck I borrowed a vacuum pump and pulled a vacuum with the old dryer in place - just to make sure everything was sealed correctly. I replaced all of the o-rings, evaporator, drained the oil out of the compressor, etc. Then, after confirming that it would hold (stayed at -30psi for about 30 minutes) I swapped the dryer and vacuumed for 48 hours. I only intended to do it for 24, but didn't have time after the first day so I just let the pump keep on running...
My point being, you may want to have the place that's recharging check it first for air tightness before putting in the new dryer - it's pretty easy to access...
Heath
