georgeNCSUee »
https://forums.nicoclub.com/georgencsuee-u31803.html
Fri Aug 19, 2005 9:49 am
Hi there!
I recently got a 95 240SX SE , wrecked, totally stock, and I am in the process of fixing it before I start with the mods (if I ever do). Right now I am trying to solve the A/C problem that's giving me headaches (and low mpg #) and although I searched around, I can't seem to find an answer for. What happens is I cannot turn the A/C off. It works ok (meaning that I can turn the compressor on and off as I please) the first half a minute or so after I start the engine after it’s been off for a while but after that, once the ignition switch is turned to 'ON', the compressor clutch engages and doesn't disengage until the ignition is switched off. It doesn't care if the A/C main switch is 'ON' or 'OFF' or what speed the fan switch is, or what button of the air direction control is pressed.
What I know for sure is that the push control unit gets power, the lights, fan speed control, and air direction control work, and when I turn the A/C switch on and off, the condenser fan starts and stops and the engine rpm increase and decrease a little, like they are supposed to, but the compressor stays engaged. If I disconnect the push control unit harness, the clutch still remains engaged. Taking out the A/C relay or disconnecting the pressure switch does disengage the compressor. I do not believe it’s a stuck A/C relay since I measured it and it looks good, and it clicks when the compressor engages.
Anyone, please help! The stock KA is weak enough without the A/C drag, but here in NC it’s still way too hot in the middle of the day to just take out the relay. Plus, I have to have everything work right, or else what’s the point of having it.
Thanks for any input!
George
