ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Wed May 25, 2011 2:04 pm
If you have a stock compressor, I think that it is a V6 piston with a variable plate offset to control the pressure. If it is blown as you say. most of the metal fragments are still in the housing, the dryer must be changed. Examine it when diss-assembling, anything past the dryer must be small, so investigate the down side of that dryer for metal chips.
The compressor out, can you turn it over by hand, if so after evacuating and capturing the R 134A verify the compressor sucks and discharges.
If indeed you have a bad compressor, check your compressor drive system and pulleys, the idler and the main crank for squareness and play and the belt for material being rubbed away.
When a new compressor is installed verify whether it has been oiled with proper oil and quantity. If you have downstream contaminants within the dryer check the hoses and condenser and the cooling evaporator inside the truck. And yes it is now an expensive repair, but it must be done correctly.
When charging a cooling system use the proper freon and amount...it's labelled on the compressor. The replacement should be the same as the damaged unit. Check out the complete A/C system.
