EviL inside »
https://forums.nicoclub.com/evil-inside-u43933.html
Mon Aug 18, 2008 11:53 pm
actually, the 95-96 240sx uses the same parts for the a/c system as the 91-94, except for the compressor. i bolted a 95 compressor and bracket to my DE swapped 90, and it works fine.
minor differences in mounting for the condensor have no effect on if it works for R12 or R134a. you SHOULD however, change your accumulator/drier and flush the system. don't worry about the expansion valve, the 91-94 and 95-98 use the EXACT SAME PART #. no "special" R134a expansion valve needed.
