My RB25 »
https://forums.nicoclub.com/my-rb25-u61932.html
Thu Aug 09, 2007 7:45 am
Many things can cause a fuse to blow, just saying its the clutch is ignorant, no offense to your Volvo buddy. You could also have a short, but if you did chances are it would blow as soon as you used the A/C or put in the fuse. Could also be a bad relay. To many possibilites to just start pointing fingers w/o actually looking into the problem.
Let me ask you something, is it the A/C fuse your replacing or the blower motor (fan)? Does the fan work when that fuse is blown?
The clutch could be hanging up and causing the compressor to work harder, pulling more amps resulting in the fuse blowing. It could also be your entire compressor going.
