Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Tue Jan 05, 2010 11:59 am
Welcome to NICO!
Unfortunately I don't think any NICO members have replaced the lamps in the A/C and recirculate buttons on the manual HVAC control unit. I do know that the lamps which illuminate the three dials are #74 (there are two bulbs). I doubt it's the same bulbs since the two buttons are much smaller; Nissan may even have used LED's to illuminate the buttons, I'm not sure. If you do disassemble the buttons, please let us know which type of lamps they require.
As far as the rear defrost button (the one below the hazard button), that uses an extremely small bulb which I'm not sure you can buy in stores. I think there may be a post somewhere on NICO on how to purchase the replacement bulb. I replaced the incandescent bulb in my rear defroster button with an LED for better/longer bulb life. There is also a post on NICO with some pictures of how to take the switch apart to replace the bulb.
