a/c button lights replacement
joe maniqz
Car: 1999 Infiniti Q45t 1992 BMW 525i 1985 BMW 635 csi
for 1999 touring, has anyone changed the lights on the "AUTO" a/c button? do i need to take the center dash off or can i just pick out the button? thanks.
tfvesquire
Car: 1998 Q45
Hi There:
To replace those bulbs, you have to remove the woodgrain shifter/ashtray trim, the center dash vents and the complete center HVAC/radio console.
Once you remove all that (check the FSM for all the hidden clips and screws) you will see the bulbs. They cost about $6 each from the dealer the last time I checked, but they may have gone up. I would buy 1-2 extra bulbs just in case so you'll have some spares.
Good luck.
Ted
joe maniqz
thanks ted, i didn't know there's a lot of work just to replace a tiny bulb. have you done it before? any words of precautions?
