No, I have not noticed this before. Condensation on the outside of the AC assembly parts sounds unique. Your heater core is in there as well, with coolant inside. Does the moisture seem like it could be coolant? Still, I'm not sure how it would be on the outside unless it was condensation. Then, you say you have it in the back seats? I don't know how it could get there other than to completely saturate the front seat area and then seep to the back. That sounds like a lot of condensation to me. Like half a gallon or so.
I looked at the FSM manual air conditioning chapter. There is a drain line from the bottom corner. It is #7 in the picture on page 76 and or 77. I googled a bit and found a couple of owners found that their drain line hose was too short and or clogged. I can't see where the hose is supposed to go in the diagrams, but if you were there under your dash, I think you'd see it. Here's a link to that.
http://www.nicoclub.com/service-manual? ... a/2011/MTC
Also, I saw some people saying there might be a technical service bulletin about it, but I couldn't confirm in my searches. The number I got for that was NTB08-101a. Got any more information?
