A/C blew ICE cold for the few min the belt was on though could it still be low on oil?And I plan on checking the switch as soon as I get home.No lights are good. Battery is brand new. I did notice when I turn the key the clock in the gauge cluster turns on but when I turn the key fully to start the car the clock fades out. Good or bad?vanquish2 wrote:Your AC compressor could be low on oil and possibly locking up.....
as far as the no start........check to make sure your clutch pedal switch is good....
do your lights dim when you turn the key and try to start???
Oil and freon are 2 different things....if the compressor is locking up it may still work ok...but put a high load on the belt....IT240SX wrote:
OK. Thanks alot. I really appreciate the help. I'll try all that when I get home at 5 and post what I find later tonight.vanquish2 wrote:
replace the belt but don't turn the ac on for a while....see if the belt shreds if the ac is not used...if it is then the bearings on the ac clutch are shot
all the accesories are meant to go off when starting to conserve energy, but what you should look for is current draw. If you have a voltmeter hook it to the battery and have a buddy watch it....if the voltage drops when you try to start it then the starter still may be to blame....if the voltage doesn't really drop then the clutch switch is possibly the problem.
Don't worry about the diagrams yet......test that clutch switch! You can use an insulated jumper wire to fake the computer out....just pull the connector off the switch at the pedal and jumper the 2 leads together. If she starts flawlessly then you know your switch is the culprit!IT240SX wrote:
The A/C will have to wait till tomorrow. But I put a Voltmeter up and had a friend start it. the voltage only dropped 0.2v. So starter is good. Next on to the wiring diagrams.......damn i hate those.......
