A/C belt beat the insulation off of harness leading to injec
91240sxxxx
Car: 1991 240sx
A/C belt beat the insulation off of harness leading to fuel injectors after carfully splicing the wires the engine turns over but still will not start. I checked all fuses,has gas, gets spark what else can I check to solve this?
zachattack_5491
Car: Pignose S13 Redtop SR
Make sure you connected the correct wires. Did you solder and heat shrink them? If not, I would recommend it. Test the wires and make sure they lead all the way to the ECU, make sure they have power and a good ground.
It's possible that two wires connected and shorted something (ECU) or melted a wire.
