Macanic »
https://forums.nicoclub.com/macanic-u303987.html
Mon Dec 06, 2021 10:06 am
Does anyone out there know of a person or persons that can reman an ac amplifier?
Do you know of a good source to get a used one, I have decided Ebay is full of cons.
A/C quit after a radio install and it is driving me nuts, all new sensors in and out, new High-Pressure switch, Freon charge correct, tried a used supposedly working amplifier, no go, PDM good, power to relay good at PDM fuse, wire from PDM to compressor good, will jump ok, it is as if the ac relay is not receiving signal when you turn ac on. Everything my manual says points to Amp. AC compressor clicks 5 times as it should in test mode.
Baffled. Any thoughts?
