cons of using SR compressor
- existing system needs to be evacuated
- custom lines need to be fabricated
- system needs to be recharged with refrigerant
- replacement SR compressor not available domestically
- requires rewiring
- fitment KA compressor onto SR bracket isn't the best
- clutch/pulley of compressor does not line up with crank and idler pulley
- requires rewiring
pros of using KA compressor
- existing A/C system doesn't need to be touched
- A/C works like stock with all stock components and nothing more
- simplifies your SR swap
My RWD SR20DE A/C bracket allows all 4 compressor bolts to be utilized, and all other's brackets only allow the use of 2 bolts. Either bracket, the pulley is still misaligned by a few mm, or the pully isn't angled perfectly.
GSRACER modified the KA compressor and is using a VG-compressor clutch/pulley. This is one solution. 2nd solution is One Ton Garage's aluminum adapter brackets which bolt onto the SR bracket and adapts it for use with the KA compressor. It's the cleanest adaptation that I've seen so far. 3rd solution is a replacement bracket. I want to get a machined aluminum part made off the OEM DE bracket:
I've been talking to a well known machining company and a well known vendor about getting a replacement aluminum bracket with the correct bolt offsets made for me and my car. For the benefit of others, it will incorporate additional bolt holes for all variations of KA compressors (S13 and S14 generations covered) to make it a universal bracket.
I'm posting this because I want to gauge interest in a bolt-on bracket to correctly adapt the existing KA compressor from both S13 and S14 to the SR20. Minimum run is 25 pieces, and the cost on the piece would be in the ballpark of $150 (roughly 1/2 the cost of using the SR compressor). It's going to be lightweight, bolt-on, and universal.
By the way, this isn't a commercial post. I'm getting one made regardless, and I was checking to see if anyone else wanted to benefit from my research and development. Also, getting 25 of them made will definitely be cheaper than getting a one-off. Anyone interested?
