a/c 2.5 headers
All things Altima Coupe.
infused305
Car: Nissan A/C 2.5s w/cvt fully loaded
are there headers out for the a/c 2.5s yet or in the works?
by the way has anyone slammed their a/c w/ coilovers? if so post some pics.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
1. Stillen was making some, never heard anything more about them... I want them too and don't care about a check engine light.
2. Only Eibach Pro kit here. The problem is the wheel wells will cause you to rub/bottom out pretty bad. For example just look up into the wheel well of the rear wheels... not much room for a lot of drop. Air ride has been done though. If you drop on coilovers or with lowering springs more than 2"s there is probably going to be a problem. It depends on what size tires and rims you're running too. I know when i hit a dip or a bump in the road it's really really close to rubbing for sure.
Eibach Prokit with 19X9.5 / 255/35 rubber:
Low enough for me to be safe on my roads anyways...
mcheddadi
Car: R8
kyle@stillen wrote:About a month or so ago we installed the headers on a forum member's vehicle "datalux." He put nearly 1,000 miles on them to test our idea for eliminating the check engine light. Thanks to his efforts we were able to prove that our engineer's concept works perfectly and there will be no check engine lights on these.
These will be marked for off-road use only as they eliminate the primary catalytic converter.
http://forums.altimas.org/zerothread?id=387863
They are coming soon and they should have big gains!
