180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Mar 10, 2004 6:49 am
1. The oem type would be good enough unless you're running on a metallic or semi-metallic. The slots are better for those types, but you'll also go through brake pads alot faster.
2. The brembo calipers probably would fit but you're looking into a custom bracket and that'll cost you. Anything can be done if you throw enough money at it.
3. define bent in, I'm not sure what you're asking for, if you're looking for a lip on the rims or what. The offset for the front that I see as a very good fit ie flush with the fenders is +20.
