Oh...if you're gonna see track time then you definitly don't wanna cheap out on the cooling side. I'd suggest draining out the anitfreeze and running 100% distilled water.DevilMB3017 wrote:And WD: My FAL fans with thermostat and fan shroud are already ordered from SPLParts. I want ZERO problems next year when I seriously start to see track time. I already know the motor/turbo takes a beating...heh However, this means no more car parts till about October, just before NicoFEST VIR. I'm going to a radiator and hoses then, and get an alignment, and see how I do the Redline Timeattack
WD
I asked because calipers are generally built around a certain rotor diameter. Moving to a larger diameter rotor while moving a caliper out could end up with a pad that hangs off the edge of the rotor slightly. Depends on many factors, but I was simply curious.DevilMB3017 wrote:None of the pad is really off the rotor, that's why I have the brackets. There is however some rotor surface that isn't in contact with the pads.
Additional brake torque can be a bad thing if the balance of brake torque between the front and rear brakes becomes poor. It can make for longer braking distances. Minor compromises to achieve better heat capacity can be acceptable if heat capacity is an issue, but I'd try my best to overall brake bias the same as stock.nelson8708 wrote:since the caliper is further from the center of the rotor it has a little more leverage...that should help a little bit as well.
This is why sooner or later I will be going to a differnet master cylinder. The S13 BMC isn't giving enough fluid to the fronts for this much braking power...I just can't decide between 1" or 17/16". I'm probably going to go 1".C-Kwik wrote:Additional brake torque can be a bad thing if the balance of brake torque between the front and rear brakes becomes poor. It can make for longer braking distances. Minor compromises to achieve better heat capacity can be acceptable if heat capacity is an issue, but I'd try my best to overall brake bias the same as stock.
