saintsinner »
https://forums.nicoclub.com/saintsinner-u25447.html
Thu Apr 28, 2005 5:08 am
ok..i was running around the forums reading up on some stuff,and i noticed alot of you guys mentioning that you guys vent your bovs into the air,now with a car that is equipped with a MAF wouldnt that make the car sputter or stall out in between shifts...because the ecu is seeing the metered air and then when the bov does its thing it actually richens up the mix because of what it did?Also have any of you ditched the maf and went with a speed density set up?
