redneck90m wrote:ok here the skinny when i ease on the throttle its sort of fine but when i go gung ho the car sputters bad and wont accel.
Hmm.Just some things I'd check (I have no idea if this is really it)
1. Unplug MAF see if car runs better or worse.2. Use a factory service manual to check that Throttle Positioning Sensor is working correctly. 3. You said your injectors are working fine, just curious, how did you know?4. Maybe your fuel pump is going out? I guess put a fuel pressure gauge in and verify that you have proper fuel pressure when you are pushing on the accelerator.
Did it just start to happen one day or has it slowly gotten worse?
