maik21 »
https://forums.nicoclub.com/maik21-u13319.html
Thu Aug 12, 2004 1:06 pm
im an owner of a 240sx ka24e motor. 90
and the question is, the aac valve (idle regulator) is active when my rpms is not at idle? my car have a problem... the rpms up to 1100 for 4 secs.. then down to 750 rmps for 4 secs... then ups to first. then go to second... and is a cicle... but.. i close up my hear to the ECCS and before my eng rev to 1100 it have a noise like a "tssssss... metal " and the aac valve idle regulator have a toc and my engine revs up. ... i check all the air conduct .. maf to eccs and the other hose that is before the throttle body that connect to the aac valve and all be ok. ... when i press the gas pedal to rev the engine to 1500, its fine and the rpms are stable....
the problem is when the motor is on idle rpms... i check the switch into the tps and its fine... but when i disconect the switch , the rpms is the same.. its have not a change. switch into tps into on position = switch into tps into off position = 750 rmps...
the ecu not show any warning. it show the code 55 ... i put ecu into real time and it not show any problem. .....
when my motor is on at 750rmps and i disconect the o2 sensor, the rpms change? .. i disconect the o2 sensor and the rpms are the same. its not change.
i have a new spark plugs and are platinum 2 electrode. new spark wires, new cap and rotor. my inyectors are clean by a laboratory inyector for 35 dlls(the inyectors was removed and clean). the resistance into the tps are ok. all the way is with resistance. extra ground to maf and body
and other stuff... the rpms are fine when the motor is cold... but when my motor is at warm temp, it fails with the problem that i show in the beggin. my air regulator (bimetal) that apear that its not working because i disconect when my motor is cold and conect at 10 secs after and theres no change into rmps. ......
i hope that all the users of an ka24e help me with this problem and other users with knowledge(i dont know how to write, but its a word that mean inteligence), help me too =)
