Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Wed Feb 13, 2008 6:17 pm
IIRC, all the lighter sockets on the Q are only "hot" when the ignition switch is turned on. The rest of the time, they aren't connected to anything. So, they won't supply any current to the engine computer unless the ignition switch is turned on.
And, when you turn the ignition switch on, it draws enough current to drain a little 9 volt transistor battery in a matter of seconds!
BOTTOM LINE: I'm pretty sure it won't work on the Q.
The last time I had to disconnect my battery to replace it, I used a small 12 volt gell-cell battery (the kind that Home Depot sells for wireless gate openers and some home security systems), using a pair of alligator clips to connect it to the Q's battery cables. This supplies 12 volts to the engine computer, without having to turn on the ignition switch or any other high-drain accessories.
