!995 KA24DE Swap
Limodash
Hi my friends, I have a 1992 240SX, the engine is on it's last leg, I was thinking replacing it with a 1995 KA24DE ...Do you think the wiring harnesses will match ?A big thanks in advance .peace
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
there are definately some difrences between your 92 and his 95 but the swap is definately do'able. your best bet to make it simple is going to be to swap out your electronics for his leaving your car stock. best plan of attack would be to use your intake on his longblock and i believe you need to use your 92 dizzy. im pretty shure your de uses an optical sensor in the dizzy for timeing and i think his has a CAS. best bet is to do a search for "de s14 to s13 swap" or something similar.
