'99 whine after timing belt change
Rabbit212
Car: 1999 Nissan Pathfinder
'99 recently had the tb changed and now I have a whine noise when reved that was not there before. Going back to the mechanic tomorrow but wondering if anyone has experience this after having the tb changed. Could the tb be on too tight?? Is that even possible?? Needs breaking in??? Opinions. Thanks all.
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Rabbit212 wrote:
Sun Apr 09, 2023 8:18 pm
Whining is not normal at all.
macgiver
Probly didn't install one or ALL idlers , one's a mistake - maybe , and so the new stronger belt along with proper 'increased' tension brought out "noise" & super-accelerated idler bearing failure ??? :wtf2:
adamzan
Car: 1995 Nissan Pathfinder
2002 Nissan Xterra SE/SC
2004 VW Golf 2.slow
Whining sound after a timing belt change is indicative of it being too tight. Nissan wants you to use tools to measure the tension but a good rule of thumb is you should be able to twist it roughly 90 degrees in the centre between the cams.
Rabbit212
Yup belt was on too tight, adjusted and now sounds and runs great. Really enjoying this old pathfinder had zero need for it but wanted something to mess around with on my days off and it fits the bill nicely.
