99 sentra OEM CD radio in 95 240sx?
Post all your Nissan electronics, car audio and stereo questions here!
nyckanny
Hi, does anyone know if the 99 sentra oem CD player will fit in a 240sx. I'm basically wondering if the damn diversity antenna would be a problem, i have the wiring harness set up ok i think. thanks!
Ken
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
You should be ok, unless the sentra didn't have a div. ant. then you'll need an adapter.
Was the 95 and SE model?
If so then with the six speaker system you will over gain the amps and damage something by turning on and playing the sentra radio since it has a built in amp and the 240 has external amps.
