di_rosa »
https://forums.nicoclub.com/di-rosa-u57480.html
Mon Apr 07, 2008 9:30 am
i brought it to Diamond Transmission, and they said it's common on these cars, the transmission cooler plugs up, and grenades the transmission. first thing to go are the planetary gears, which is the light grinding noise i'm hearing mainly in 1st gear, because that has the most load on it.
so, assuming i caught this early enough, what do you think the chances of the transmission lasting long enough if i do a filter, flush and fill, and get an aftermarket oil cooler?
he said it's ~$3k to rebuild, not exactly what i have laying around
