99 QX4 Power Window Problems
kmorris
Car: 1999 infiniti qx4
1999 QX4 Helping a friend with a passenger side window problem. Both passenger front and rear window will not open with master switch. New Master switch tried same problem no change. Passenger front switch will make the window go down but not up. With leads switched window goes up so motor works. Passenger rear switch does nothing. Have not checked rear motor yet. Both driver side window work great. Thanks for the help.
asnorton44
Car: 2001 Infiniti QX4
Maybe rear passenger switch when mine went bad it took out both rear windows.
