asoomal »
https://forums.nicoclub.com/asoomal-u90618.html
Mon Sep 02, 2013 7:47 pm
Remove the LH headlamp relay and check and see if the high beam indicator is still on. The LH headlamp relay circuit goes to the LH high beams and the high beam indicator.
Or you can remove the 15A fuse for that circuit.
If it turns off, then it is very likely that the switch needs to be replaced since it was getting power from terminal #9 when it shouldn't be.
If it still stays on, check and see if it's still getting power from terminal #9, if so, switch is damaged. (Internal short?)
If not, then it's the theft system wiring. According to the FSM, there is nothing else tied to the high beam indicator lamp wiring.
