Avalanche325 »
https://forums.nicoclub.com/avalanche325-u135425.html
Wed Jun 03, 2009 3:58 pm
Hi everyone. Man do I need help.I have a 99 QX4 with 135K on it.
I was backing out of the garage and suddenly it started to shudder. I shut it off, and then had trouble starting it. When it did start, it would idle fine, but as soon as I touched the gas or put it in gear it would stall.
Symptoms: Hard to start (most of the time)Will idle fine in parkIn gear has an occaisional miss (when it stays running)Sometimes I can drive it for a short distance.I can rev it at partial throttleFull throttle will make it stallNo check engine light
I have spark. So I went for the fuel system. Good pressure at the pump.I changed the fuel filter, fuel pressure regulator, and then the TPS. I cleaned the MAF. It is still doing the same thing.I am now pulling my hair out. (works as well as anything else I have done)
It is still doing the same thing. Please help.
