hill84 »
https://forums.nicoclub.com/hill84-u228811.html
Wed Dec 11, 2013 12:55 pm
I have a 1999 Infinity QX4 that I have a few questions about. First off it is more of a spare vehicle more than a daily driver... So about a month ago on the way home from work and pulling out from a blind intersection (took the short route home) I had to drop the accelerator to the floor to flow with traffic. On the first shift I lost oil pressure, oil light came on, and the engine started knocking. I was about ½ of a mile from the house so I backed off of it and babied it home. I let it set for about 30 min and went back to start it back up. It had a horrible knock on startup that lasted for about 5 sec then went away. Since that day I have not driven the truck over a couple hundred yards at a time and it still has the knock on startup. Once the engine has been started and the initial knock clears up you can only hear a slight ticking right before the transmission changes gears. If you kill the engine and start it back up you don’t get the initial knocking only when it attempts to change gears. My question is what has happened and how do I get it fixed.
Sorry for the long post
Nathan
