99 QX4 - brake applied and tach surges
99.5 qx4
Car: 99 QX4
My qx4 is acting weird. When driving at 65-70 mph (no cruise) and the brake is applied, the tach surges from 2500 to 3500 before settling back. Took car to local mechanic, no codes (other than stored O2's with no check light). Car has not had onboard computer upgrades since I've owned it (2 years). They checked mechanical and can find no apparent cause. They suggest taking car to dealer to have all computer upgrades (~$175). They suspect it may be computer related since the throttle is controlled electronically. Know of any specific TSB's or have any suggestions?
I searched through the forums looking for tach surge, brake and tach surge and found nothing related
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
So it ONLY does it when braking, or does it do it under general deceleration???
Seems weird, but i really doubt the dealer would help you much.... Let me think about this.
99.5 qx4
Car: 99 QX4
It is only when the brake is applied and it happens at both lower speeds 35-45 up to higher highway speed. It is as if you get a burst of gas. Not really surging the car forward but just revving the engine.
Q451990
On the Q45 there's a check valve in the vacuum line that goes to the brake booster. If the QX4 has this, and something was weird with it, could that cause an issue - e.g. pushing a surge of air into the intake? Just a thought...
Heath
elwesso
2007 BMW M Coupe
great thought heath!!!!! id check it!
99.5 qx4
Car: 99 QX4
Sounds like a possibility. How do I check this and/or replace it? Is it something that will be obvious when I look at the line to the brake booster?
Q451990
Here's a page from the FSM for a 99 QX4. I think this is a long shot - but worth checking.
Heath
99.5 qx4
Car: 99 QX4
Looked over this whole assembly and no apparent problem with the hoses. Removed the check valve and blew air through it. It seemed to have a 'catch' initially. It may have been sticking. Did not have vacuum tool to check it so reinstalled and it is much improved. Still does it but not as much. Ordered replacement and will see if problem goes away completely. It will be a few days. I'll post again after new part installed.
elwesso
2007 BMW M Coupe
how much was the new check valve?
99.5 qx4
Car: 99 QX4
It was $30 (through Nissan dealer p/n 47478-51E00 --$42 @ Inifiniti) -- Couldn't cross reference at any local parts store, so stuck with dealer. Do you know of a cheaper place? Also decided to replace the retaining clip (plastic broke on removal) at about $16.
elwesso
2007 BMW M Coupe
Thats not too bad... $22 from Joe at http://www.infinitipartsusa.com by the time you factor in shipping ($5 minimum charge) not really saving much.
Q451990
Please let us know how it all turns out... even if you are from Arkansas That was a nice butt whooping you guys put on us earlier tonight. (Ignore my rambling if you aren't a football fan)
Heath
99.5 qx4
Car: 99 QX4
Go HOGS!! Wooo Pig Sooie!
99.5 qx4
Car: 99 QX4
Sorry this took so long but wanted to report that replacing the check valve DID fix this problem! You're a WIZARD!!! Thanks so much for all of the help!
elwesso
2007 BMW M Coupe
Excellent, glad it was very simple!!!
This forum=+1 point
Q451990
99.5 qx4 wrote:Sorry this took so long but wanted to report that replacing the check valve DID fix this problem! You're a WIZARD!!! Thanks so much for all of the help!
Talk about a long shot working out... That's great news!
Heath
