99 Q45 Trunk Swap?
himynameisnotjoby
Car: 1999 Infiniti Q45
I currently have the trunk without the taillights and would like to swap out to get the "full" taillight look instead.
1. Does anyone have photos of the swap as they were going through the process?
2. Can I only use a 99 trunk with taillights or can I use a trunk from any year?
EdBwoy
I believe the 97 and 98 trunk is what you're looking for. I haven't seen any threads with the swap, so I'm not sure if the outer lenses are the same size. You might need to check the wiring diagrams in the FSM (link in sig) to see what wires would need to be moved as well. As you know, your trunk only carries the reverse light, while the other carried 3 lenses (maybe 2 lights and a reflector? :gotme )
EdBwoy
Eh, spoke too soon. Look what my search turned out:
post6231549.html?hilit=trunk%20swap#p6231549
Welcome to the forum, good luck.
