99 Q45 Suspension
Bigmoe1315
Car: 1999 Q45
I just purchased a used 99 yesterday and I need to fix a noise under the car.It makes a noise when I brake .I can`t find any suspension parts anywhere with a diagram so I can look at and find the part?If someone has any good part stores online with diagrams pleas respond or if you`re in the DC area and know a good mechanic please help.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Here are the Nissan FAST (Dealer) diagrams:
If you need any more pictures or infomations please see the service manual: http://Nicoclub.com/FSM
Welcome to NICO.
Bigmoe1315
Car: 1999 Q45
thanks sir i found out I need a lower control arm which are hard to find since I don`t want to pay dealer prices.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
try Infiniti of scottsdale, info is in my signature. Any mechanic should be able to replace the part, its very straight forward.
How did you determine it was the lower control arm?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Bigmoe1315 wrote:thanks sir i found out I need a lower control arm which are hard to find since I don`t want to pay dealer prices.
Once again , call Joe and his crew at IoS
http://www.infinitipartsusa.com
Have your VIN handy
Are you sure it is not the tension rod bushing? That can be purchased separately. Replaced both sides at once.
Look for Qship96 post for an Infiniti Senior Technician at Hill's Garage.
trajanH
Car: 1997 infiniti Q45T
It might not really be the lower control arm because that part is not the first to fail. Check your Tension Rod bushings and the Stabilizer Rod. I had a similar problem with my 97 Q45 and I went on a wild goose chase looking for a lower control arm bushings because I did not want to pay dealer prices for the complete part when you only would need the bushings.It turned out that my Tension Rod bushings(#54776) and Stabilizer Rod(#54618) was the real problem.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
trajanH wrote:It turned out that my Tension Rod bushings(#54776) and Stabilizer Rod(#54618) was the real problem.
The latter commonly known as the front anti-sway bar link.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
What is your mileage?
I would say anything over 75k for sure your tension rods are done. Mine gave up the farm around that mileage.
You should also consider shocks/struts if your going after the suspension. there are not many choices out there, KYB SR Specials are a good aftermarket replacement but will take some time to get delivered. If you have the touring electric shocks you will have to invest in replacements from OEM.
If your over 75 TRUST ME the shocks/struts are gone along with the tension rods.
Bigmoe1315
Car: 1999 Q45
Will these parts be comparable or the same as a sway bar link kit sold at advance auto.Moog Sway Bar Link KitPart No. K9834Frt Susp; LH; 1 Required
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Aftermarket is a crapshoot, with many disappointments and few finds.
Report back after 10K miles if you use them.
trajanH
maxnix wrote:Aftermarket is a crapshoot, with many disappointments and few finds.
Sorry, but I'm not digging that advice. I just replaced OEM sway bar links on my 97 Q45 with aftermarket sway bars that I bought on ebay(by way of Taiwan) and I like the aftermarket ones better. One of the things I like better is the lock nuts with nylon inserts that wont freeze up and rust onto the car. You will appreciate that when it is time to change the sway bar and you wont have to pay extra to cut the bolt off.
