maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Wed Oct 15, 2008 5:05 pm
Did you measure hub run out? Bearings and ball joints still tight?
Assume tension rod, steering rack and sway bar llink bushings all new?
How are front struts and bearings? Tire, wheel, rotor and pad data, please. Finally, did you true the rear rotors also and replace with OEM pads? Use high temperature lubrication on the caliper pins? New shim kits?
