Benosn99 wrote:Symptoms: Everything works fine except at stop light, I get a slight, variable, "stumble" from the engine... pasenger can't always feel it but I can because I'm "connected" via the gas pedal (and everything runs great at higher RPM's). Replacing the coil in this car (and in my old Q45) always fixed the problem. $645 to fix one... and they want to replace all of them while the engine's apart.
Coilpacks are $174 from Joe. Easily installed if you are experienced and/or have a torque wrench. OBD II gives codes as to which cylinder is misfiring, and coilpacks interchange with other locations to aid in deductive diagnosis.
There is a previous thread about this problem already, so try a search using stumbling as the search word in the body and subject of recent posts in this forum.
