anovak1 »
https://forums.nicoclub.com/anovak1-u271101.html
Fri Jan 13, 2017 8:05 am
To open up the front, remove the side plate (the fog lamp is a rectangle, and then theres a side piece that makes it fit to the contour of the bumper, but it´s just plastic) and behind the side plate are two bolts. From here you can take out the fog lamp completely without going behind anything. There is no way to remove the fog lamp from behind. You might be able to take out the bulb, but it´s honestly easier from the front.
