slideride1280 »
https://forums.nicoclub.com/slideride1280-u162979.html
Sat Jun 19, 2010 6:49 pm
I need help! I was changing the alternator out on my 99 Q45 and the wire harness connector broke!!! it has 3 different colored wires going into that plastic 3 prong. and it was so brittle and just broke. I need help figuring out order of those 3 wires. I don't understand as the alternator has a only 2 Prongs on the alternator side. Anyone have pictures of the CORRECT ORDER or which Wires go to which prong?
Also. I understand that the Nissan Maxima 97-99 Alternator uses the SAME hook up to a similar 2 prong alternator that goes to that car. ANY way I can go cut back the wiring and sauder the wiring together on my Q45 3 prong wires and make a connector that way?
Pictures and Help would be appreciated, thanks!
Due to heat and the fact its an 11 year old car. the Plastic became weak I guess. It was hard to push down and pull out of the old alternator and it cracked then too and when installing and pushing down it cracked to pieces like nothing! Please help ASAP I'm thinking it may be an easy fix?
