99 Q spark plug and coil replacement.
99qdriver
Car: 99 Infiniti q45t
Does anyone have photos? At first glance, can't find coil packs. I've only removed the decorative cover and the air assembly.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
I'm not being a smart a## but look again. They are directly in the middle of each valve cover held on with two bolts with phillips heads. DON'T use a screw driver to remove them-either 8 mm or 5/16" socket.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Please, for your car's sake, RTFSM.
http://www.nicoclub.com/FSM/Q45/
99qdriver
Thanks
99qdriver
LOL..I did say first glance
NightRiderQ45
Car: 1998 Infiniti Q45
maxnix wrote:Please, for your car's sake, RTFSM.
Can someone make this a sticky?? I needed this when my fuel pump went out on me in a rural, very rural section of MS when I was traveling back to Alabama!!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
NightRiderQ45 wrote:Can someone make this a sticky?? I needed this when my fuel pump went out on me in a rural, very rural section of MS when I was traveling back to Alabama!!
Wow, first fuel pump failure I can recall on a FGY33!
Well, it is bound to happen.
NightRiderQ45
maxnix wrote:Wow, first fuel pump failure I can recall on a FGY33!
Well, I guess i made history huh or other people are not reporting their issue. Well the OEM fuel pump almost made it 11 years...but 10yrs is great! It was a scary situation, especially where I was located, but with the help of this board, I was able to locate the FSM(after 30 mins of searching) and pin point that it was a fuel pump problem. Thats why I wanted the FSM to be a sticky. It actually should.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
NightRiderQ45 wrote:It was a scary situation, especially where I was located, but with the help of this board, I was able to locate the FSM(after 30 mins of searching) and pin point that it was a fuel pump problem. Thats why I wanted the FSM to be a sticky. It actually should.
Why they are downloaded and bookmarked in all my computers along with Joe's number in my Contacts.
NightRiderQ45
True. I have done the same thing on my computer, but I was in MS and the guy who was helping me with my car needed it...of course he didn't know anything about NICO, but I was able to find it after searching.
