99 q overheating
redtopsdrop
Car: 99 q45
i changed out my knock sensors, and now after hooking back up radiator, it started running hot. i filled it back up, and thought i got all the air out. ended up changing to electric fan, since clutch fan was crapping out. drove it today, got home and the radiator blew out. went a looked at it and it was cracked across the top. so now i have a radiator on order. and ideas on what could keep me overheating. i keep thinking there's a bubble in the system somewhere, but where is there a bleeder on these things. any info is appreciated.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
You should replace everything while you have it apart, hopefully this will be the last time. My 97' has never even been above 1/2 point in the hotest weather with A/C on so these cars usually run quite cold. The thermostat is probably old and needs replacement as well. Hopefully you didn't do any real damage when it overheated. What brand of radiator did you buy?
redtopsdrop
Car: 99 q45
i bought an oe replacement. aluminum jobber. i plan on selling the car so no need for koyo or anything, just a step above stock. i'm gonna go ahead and replace the tstat while everything is out. before doing the knocks it ran cold.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
When you say "They run cold" what temperature do they normally run at?
Skibane
Car: 2000 Q45 AE 110K
redtopsdrop wrote:ended up changing to electric fan, since clutch fan was crapping out.
I don't think there's an electric fan in the entire universe that compares to the cooling power of an OEM fan and fan clutch in good working order. When the clutch locks up and the engine is spinning at 2000+ RPM, there is a truly massive amount of air being pulled through the radiator - You'd need hundreds of amps of 12 volt current to produce the same amount of airflow with electric fans.
I would suggest selling your electric fan on ebay, and coughing up the money for a genuine OEM fan clutch.
BadQ45t
The gauge runs not even half-way.....not sure what that temp is but it isn't 1/2 up the gauge.
redtopsdrop
Car: 99 q45
took your advice and ordered an oem fan clutch and a new thermostat. i'm gonna porbly just hang on to the electric fan for later use on something.
Infinitiguy19
Use it to cool the transmission cooler you should add on if you haven't already.
redtopsdrop
Car: 99 q45
thats not a bad idea.
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
As far as bleeding the cooling system goes, head down to the part store and get yourself a cooling system funnel. They have radiator adapters that allow you to run the car with the radiator open for bleeding. Turn the heater on full hot, and the fan off. Start the car. Warm the car up until you reach full operating temperature and let it idle for about 10 minutes. If you have an air pocket this bleeding method will "burp" it.
