'99 q-need used TCU/TCM(?) please!
dodiho
Car: 1996 I30 1999 Q45
the "stealership" in Dallas wants $1000 for a new TCU/TCM for my '99....this is ridiculous--would some of my Q45 friends have a good used one for sale? They said it was shorted out/grounded out and ruined during a sever rain storm-must be true as my cruise went out and the ABS/SLIP/TCS lights came on at the same time..and stay on....Thanks!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It is odd that a flooded ECU (how?) would lose only those functions.
Better cure the leak first then worry about the electronics. Bet there is a TCS relay like the G50. What does the FSM say?
ABS/slip/TCU is calssic indication of failing alternator. Better check that first.
Modified by maxnix at 12:17 PM 4/2/2008
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
dodiho wrote:the "stealership" in Dallas wants $1000 for a new TCU/TCM for my '99....this is ridiculous--would some of my Q45 friends have a good used one for sale? They said it was shorted out/grounded out and ruined during a sever rain storm-must be true as my cruise went out and the ABS/SLIP/TCS lights came on at the same time..and stay on....Thanks!
How many posts have you started about this problem? I still don't know what you've replaced/fixed/repaired.
If the TCU/TCM was shorted it seems that many other functions would be lost but....
Anyways, I'll sell you one for 97 for cheap with lots of disclaimers.
Q45tech
Traction Control Unit [computer module] controls TCS/ABS don't confuse with TCU Transmission Control Unit.
dodiho
Q45Tech........the tech said it was the module that controled the TCS/SLIP/ABS and I didn't hear exactly what he called it--so it must be the Traction Control Module.......will BulletAndy's '97 one fit my '99? after checking ,fuses,relays that were OK, the dealership in Dallas told me that some of my wires under the hood had "shorted" out the TCM and that's why the lights are on in the dash and why my cruise won't work. I am READY to fix this problem----the trans shifts fine and I have no other problems with the car-except the occasional "stumbling" at idle.....isn't the TCM located on the passenger side kick panel area? near the ECM? Thanks,Doug in Texas
Q45tech
I refuse to work on [ignore as much as humanly possible] Q41/Cima F50 so read your FSM for location.Perhaps someone else.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If it is the wires, I would replace that portion of the harness.
You need a second opinion from a qualified senior Infiniti technician.
