I don't believe so, but I need to verify with the mechanic.
I ran across the following in a search of the forum for Power Steering problems & it looks like there are a lot of other possibilities to consider for this problem: Any additional input would be appreciated. Thanks!
Re: Q45- Power Steering Problems (dbutler249)
by Q45tech » Thu Mar 26, 2009 11:02 am
Historically [over a few thousand Q45 serviced] the pump is the last thing to fail. Idler bearings and belts fail before flex hoses, then hardline crimp adapters/transistions leak, rack seals, and the last thing is a pump..........unless the PS fluid was allowed to become brown and full of wear metal grinding down the pump blades [rare].
Copyright 2010. Nipuspan International Corporation. All rights reserved. This material may not be broadcast, rewritten or redistributed.
http://www.t3atlanta.com/
Q45tech
Car: 1990 Q45 342,400 miles 21 years ownership with original engine
1995 G20t 5 speed 304,000 miles 16" 2002 wheels - 205/50/16
