albbountyhunter »
https://forums.nicoclub.com/albbountyhunter-u197412.html
Mon Jan 23, 2012 1:21 pm
I have a 1999 Nissan Pathfinder 4x4 3.6L V6 with automatic transmission. My #18 fuse (AT CONT) 10A keeps blowing when I turn the key. The red lights, on the console, light up and there is no response from the starter. It will blow the fuse whether I turn the key part way to the ON position as well as when I turn the key to the START position. If I remove the N-P relay (Neutral Position) I still get a blown fuse in both the RUN and START positions. When I unplug the black/pink wire from the starter, with the N-P relay still removed, the fuse does not blow. I had initially replaced the starter thinking that was the problem. The vehicle ran fine for a few days then the fuse blew again. With the connector unplugged I tested the wire for continuity to ground from terminal 7 of the N-P relay. It did not show any conductivity. This indicates to me that the wire itself is not touching ground. Could I have a defective starter? If I connect the black/pink wire to the starter and test for continuity, from terminal 7, I get continuity to ground. That doesn’t seem right. Any thoughts would be appreciated.
