99 Pathfinder washer sprayer nozzle
99lanshark
Since I bought my 99 Pathfinder LE this spring, I have always been let down by the streams of washer fluid that comes out of the nozzles. Every other car I had, had a spray that fanned out over the windshield,but this one has 2 streams that squrit out on both sides. Is this Normal for this car ? If so, can I replace them so I can get a spray and if its not normal, can I adjust the nozzles to make them spray instead of stream ?
Thank you in advance for any help I receive.
slickroger
Car: 2001 Nissan Pathfinder
Not sure what you mean by it streams but you can always get a pin and adjust those little nozzles to spray where you want them to.
Stick the pin in the spray hold and move.
My original nozzles have three spray holes on each.
99lanshark
A stream of washer fluid - like a stream of water comming out of a water gun. Yes I can adjust them to where I want the stream to go - But I want a spray that fans across the windshield, not 4 streams directed right at the windshield.
KyooX4
Car: 2001 Infiniti QX4 4wd
They all have streams, there's nothing wrong with yours. As far as making them spray instead of stream, I don't know, sorry.
longhornsqx4
Car: 2001 Nissan Pathfinder 3.5L VQ35DE
You can buy aftermarket nozzles for a couple bucks that shower instead of stream
That was one of the first mods I did lol, they were like 11.99 at autozone called turbonozzles or soemthing
99lanshark
Thank You !! I Knew there had to be someone out there with this kind of info.
